[GRASS-dev] Problem compiling ximgview in the latest grass_trunk
Markus Neteler neteler at osgeo.org
Thu Jul 12 01:37:10 PDT 2012
On Thu, Jul 12, 2012 at 9:02 AM, Pierre Roudier
<pierre.roudier at gmail.com> wrote:
> Hi,
> I must be missing something because I can't compile grass7.svn on a
> new config. The compilation error is located in
> grass_trunk/visualization/ximgview (see below).
> roudierp at mangatainoka:/usr/local/src/grass_trunk/visualization/ximgview$ make
> OBJ.x86_64-unknown-linux-gnu/main.o: In function `draw':
> /usr/local/src/grass_trunk/visualization/ximgview/main.c:121:
> undefined reference to `XPutImage'
You are likely missing the package "libX11-devel".
Hope this helps,
Markus
