[GRASS-dev] Problem compiling ximgview in the latest grass_trunk
Pierre Roudier pierre.roudier at gmail.com
Thu Jul 12 14:34:27 PDT 2012
Thanks for your help Markus and Glynn,
I do have libx11-dev installed (I'm running Xubuntu 12.04), but still
get the same error unfortunately,
Pierre
2012/7/12 Markus Neteler <neteler at osgeo.org>:
> On Thu, Jul 12, 2012 at 9:02 AM, Pierre Roudier
> <pierre.roudier at gmail.com> wrote:
>> Hi,
>> I must be missing something because I can't compile grass7.svn on a
>> new config. The compilation error is located in
>> grass_trunk/visualization/ximgview (see below).
>> roudierp at mangatainoka:/usr/local/src/grass_trunk/visualization/ximgview$ make
>> OBJ.x86_64-unknown-linux-gnu/main.o: In function `draw':
>> /usr/local/src/grass_trunk/visualization/ximgview/main.c:121:
>> undefined reference to `XPutImage'
> You are likely missing the package "libX11-devel".
> Hope this helps,
> Markus
Scientist
Landcare Research, New Zealand
