[GRASS-dev] limits of r.patch
Markus Neteler
neteler at osgeo.org
Mon Jul 16 13:46:17 PDT 2012
On Mon, Jul 16, 2012 at 2:59 PM, Margherita Di Leo
<dileomargherita at gmail.com> wrote:
> Strange, I just recompiled it with bigtiff support.. how can I check if the
> support is actually active or not?
When you run "configure", it will give you a list of enabled/disabled
options (prior to compilation). Check there...
And be sure that you have only one installation of the GDAL libs
on your system.
Markus
