[GRASS-dev] limits of r.patch
Margherita Di Leo
dileomargherita at gmail.com
Tue Jul 17 00:12:49 PDT 2012
Markus,
Thanks for suggestions,
On Mon, Jul 16, 2012 at 10:46 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Jul 16, 2012 at 2:59 PM, Margherita Di Leo
> <dileomargherita at gmail.com> wrote:
> > Strange, I just recompiled it with bigtiff support.. how can I check if
> the
> > support is actually active or not?
> When you run "configure", it will give you a list of enabled/disabled
> options (prior to compilation). Check there...
I get:
LIBTIFF support: internal (BigTIFF=yes)
LIBGEOTIFF support: internal
> And be sure that you have only one installation of the GDAL libs
> on your system.
Before compiling gdal I've removed the package coming from red hat.
Yesterday I've tried with:
CACHE="--config GDAL_CACHEMAX 8000 -wm 2000"
Now I don't get any error and the job is moving on somehow, but it is
taking forever so I think I should try to adjust better the parameters...
Dr. Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120717/2d957ec7/attachment.html>
