[GRASS-dev] limits of r.patch
Margherita Di Leo
dileomargherita at gmail.com
Tue Jul 17 06:45:25 PDT 2012
Hi Helmut,
On Sun, Jul 15, 2012 at 10:14 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> using GDAL Virtual Format [1] by building a virtual dataset by
> gdalbuildvrt?
> it's really a nice gdal utility:
> no need to patch all ASTER GDEM tiles within grass, just import the virtual
> dataset by r.in.gdal or link it by r.external
> [1] http://www.gdal.org/gdal_vrttut.html
> [2] http://www.gdal.org/gdalbuildvrt.html
I decided to follow your hint and explore the way of gdalbuildvrt. I'm
using:
gdalbuildvrt -input_file_list
/home/leomarg/Desktop/aster/elenco_aster_europa \
/home/leomarg/Desktop/aster/mosaic.vrt
and the process takes only few seconds, without complaining. The problem
raises when i try to import it in GRASS:
r.external input=/home/leomarg/Desktop/aster/mosaic.vrt output=mosaic
Projection of input dataset and current location appear to match
Importing band 1 of 1...
ERROR 4: `ASTGTM_N33E000_dem_lzw.tif' does not exist in the file system,
and is not recognised as a supported dataset name.
Link to raster map <mosaic> created
r.info map=mosaic
| Layer: mosaic Date: Tue Jul 17 15:43:08
2012 |
| Mapset: PERMANENT Login of Creator:
leomarg |
ASTER_GDEM |
| DataBase:
/forest/GRASS/grassdata |
| Title: ( mosaic
| Timestamp:
none |
| Type of Map: raster Number of Categories:
0 |
| Data Type:
CELL |
| Rows:
140401 |
| Columns:
198001 |
| Total Cells:
27799538401 |
| Projection:
Latitude-Longitude |
| N: 72:00:00.5N S: 32:59:59.5N Res:
0:00:01 |
| E: 44:00:00.5E W: 11:00:00.5W Res:
0:00:01 |
| Range of data: min = 0 max =
0 |
| Data
Description: |
| generated by
r.external |
Comments: |
| r.external input="/home/leomarg/Desktop/aster/mosaic.vrt"
output="mo\ |
saic" |
what am i missing?
Thanks!
Dr. Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120717/7c8412a5/attachment-0001.html>
