[GRASS-dev] limits of r.patch
Helmut Kudrnovsky hellik at web.de
Tue Jul 17 07:29:54 PDT 2012
hi,
>r.external input=/home/leomarg/Desktop/aster/mosaic.vrt output=mosaic
>Projection of input dataset and current location appear to match
>Importing band 1 of 1...
>ERROR 4: `ASTGTM_N33E000_dem_lzw.tif' does not exist in the file system,
>and is not recognised as a supported dataset name.
tested here with srtm-tiles for whole europe:
the tiles are in subfolders
C:\data\gisdata\srtm412011\srtm_35_03
C:\data\gisdata\srtm412011\srtm_36_04
the virtual dataset file is in
the link to the tiles within the vrt-file
<ComplexSource>
      <SourceFilename
relativeToVRT="1">srtm_35_03\srtm_35_03.tif</SourceFilename>
      <SourceBand>1</SourceBand>
      <SourceProperties RasterXSize="6000" RasterYSize="6000"
DataType="Int16" BlockXSize="6000" BlockYSize="1"/>
      <SrcRect xOff="0" yOff="0" xSize="6000" ySize="6000"/>
      <DstRect xOff="0" yOff="12000" xSize="6000" ySize="6000"/>
      <NODATA>-32768</NODATA>
    </ComplexSource>
link with r.external is ok:
 r.external --verbose input=C:\data\gisdata\srtm412011\srtm41.vrt
output=linkedsrtm2
 Die Projektionsinformationen des Eingabedatensatzes und der aktuellen
Location scheinen   übereinzustimmen.
 Fahre mit dem Import fort...
 Erstelle Graustufen Farbtabelle für <linkedsrtm2> (Datenspanne).
 Erstelle Support-Dateien für <linkedsrtm2>.
 Link zur Rasterkarte <linkedsrtm2> erzeugt
r.info map=linkedsrtm2 at srtm
 | Layer:    linkedsrtm2 at srtm               Date: Tue Jul 17 16:22:03 2012
 | Mapset:   srtm                           Login of Creator: myricaria
 | DataBase: \grassdata
 | Title:     ( linkedsrtm2 )
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 0
 |   Data Type:    CELL
 |   Rows:         24000
 |   Columns:      48000
 |   Total Cells:  1152000000
 |        Projection: Längen- und Breitengrad
 |            N:        60N    S:        40N   Res: 0:00:03
 |            E:        30E    W:        10W   Res: 0:00:03
 |   Range of data:    min = -444  max = 4783
 |   Data Description:
 |    generated by r.external
 |   Comments:
 |    r.external input="C:\data\gisdata\srtm412011\srtm41.vrt" output="lin\
 |    kedsrtm2"
could it be a path issue on your side?
> gdalbuildvrt -input_file_list
> /home/leomarg/Desktop/aster/elenco_aster_europa \
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/limits-of-r-patch-tp4988265p4988827.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
