[GRASS-dev] [GRASS-SVN] r52423 - grass/trunk/gui/wxpython/xml
Martin Landa
landa.martin at gmail.com
Fri Jul 20 07:17:33 PDT 2012
2012/7/20 <svn_grass at osgeo.org>:
> Author: annakrat
> Date: 2012-07-20 07:01:33 -0700 (Fri, 20 Jul 2012)
> New Revision: 52423
> Modified:
> grass/trunk/gui/wxpython/xml/menudata.xml
> Log:
> wxGUI/menudata: remove command name from menu when using custom dialog (not to confuse the user)
> @@ -207,7 +208,6 @@
> <help>Converts vector layers into a GRASS vector map using OGR.</help>
> <keywords>vector,import</keywords>
> <handler>OnImportOgrLayers</handler>
> - <command>v.in.ogr</command>
> </menuitem>
hm, after this change it will be not possible to find `v.in.ogr` in
Layer Manager's search tab (based on command name). On the other hand
the users probably would expect autogenerated dialog for v.in.ogr not
a real front-end. Anyway I would suggest to keep the `command` tag in
this case to make them searchable via Layer Manager search engine
(key: command).
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
