[GRASS-dev] [GRASS-SVN] r52423 - grass/trunk/gui/wxpython/xml
Anna Kratochvílová
kratochanna at gmail.com
Fri Jul 20 07:43:22 PDT 2012
On Fri, Jul 20, 2012 at 4:17 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2012/7/20 <svn_grass at osgeo.org>:
>> Author: annakrat
>> Date: 2012-07-20 07:01:33 -0700 (Fri, 20 Jul 2012)
>> New Revision: 52423
>> Modified:
>> grass/trunk/gui/wxpython/xml/menudata.xml
>> Log:
>> wxGUI/menudata: remove command name from menu when using custom dialog (not to confuse the user)
>> @@ -207,7 +208,6 @@
>> <help>Converts vector layers into a GRASS vector map using OGR.</help>
>> <keywords>vector,import</keywords>
>> <handler>OnImportOgrLayers</handler>
>> - <command>v.in.ogr</command>
>> </menuitem>
> hm, after this change it will be not possible to find `v.in.ogr` in
> Layer Manager's search tab (based on command name). On the other hand
> the users probably would expect autogenerated dialog for v.in.ogr not
> a real front-end. Anyway I would suggest to keep the `command` tag in
> this case to make them searchable via Layer Manager search engine
> (key: command).
ok, I wasn't aware of that. I added instead a condition (on handler
name) in the menu.py
Anna
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
