[GRASS-dev] [GRASS-user] please help review osgeo live dvd summary docs
Helena Mitasova
hmitaso at ncsu.edu
Wed Jul 25 20:57:04 PDT 2012
Hamish,
thanks for pointing it out - there was a lot of stuff that I did not know was there,
it should be cleaned up now, please let me know if you still find something
or if there are any problems. Also, I can export the data into some external formats - perhaps shape files
and geotiff? in case somebody would like to use it with other software.
http://courses.ncsu.edu/mea792/common/media/gisdemo.zip
Helena
On Jul 25, 2012, at 1:20 AM, Hamish wrote:
> Hamish:
>>> Due to severe space limitations on the disc I'm continually concerned
>>> about having to remove the NC dataset, or cut it down to Helena's 40mb
>>> set.
> Helena:
>> Hamish - I highly recommend to use this smaller dat set - it
>> is much easier for users to understand (as I tried to avoid various
>> obscure names there) and you can still do a lot with it and the simple
>> names also allow for more generic quickstart docs (e.g. if somebody wants
>> to use elevation or streams in other countries)
>> I started to use it as a baseline data set and then expand
>> it with various specialized mapsets for more advanced courses.
>> here it is again (it should be the same as on the grass website)
>> http://courses.ncsu.edu/mea792/common/Assign_GISamodel/Assignall.html
> ok, done.
> I note some left over Mac ._files and some empty .tmp/ cruft, and also
> the SEARCH_PATH in user1 lists some mapsets not shipped with the smaller
> dataset. harmless, but..
> thanks,
> Hamish
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
