[GRASS-dev] Image Segmentation - GRASS - GSoC report #10
Eric Momsen
eric.momsen at gmail.com
Fri Jul 27 20:19:06 PDT 2012
Hi all,
Here is the weekly report.
Completed:
* Finished 2 ToDo tasks that should have sped up the algorithm. One
was helpful, the other wasn't.
* Started implementing the feature to allow the user to give start
seeds for the segments.
* Started implementing a Z-order (instead of row major order) processing loop.
Plan for next week:
* Put the segment ID's into a SEG file to save RAM
* Finish work on the starting seeds
* Continue with other todo's, maybe to include user input for how much
RAM is allowed for the program to use.
Blocking:
As the program gets larger, adding new functions seems to take longer
because of unforeseen side affects.
Regards,
Eric
