[GRASS-dev] [GRASS GIS] #1672: gcpmanager fails to list source mapsets if non-ascii characters in grass data dir path
trac at osgeo.org
Fri Jun 8 21:48:40 PDT 2012
data dir path
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.2
Keywords: georectifier, UnicodeDecodeError | Platform: Linux
Cpu: x86-64 |
[Hi, one fwd'd from the Debian bug tracker, http://bugs.debian.org/676190
--H]
To: Debian Bug Tracking System
Subject: grass-gui: gcpmanager fails to list source mapsets if non-ascii
characters
Date: Tue, 05 Jun 2012 14:35:48 +0300
Package: grass-gui
Version: 6.4.2-1
Severity: normal
Using the wxpython GUI Georectify tool is impossible if the path to the
grass
data directory (e.g. GRASSDATA) contains non ascii characters (e.g.
'/home/user/Työpöytä/GRASSDATA'). Selecting the source location works, but
the 'Select source mapset:' dropdown menu remains greyed out. The command
console shows the following error message, after selecting the source
File
"/usr/lib/grass64/etc/wxpython/gui_modules/gcpmanager.py",
line 377, in OnLocation
tmplist = os.listdir(os.path.join(self.grassdatabase,
self.xylocation))
File "/usr/lib/python2.7/posixpath.py", line 71, in join
path += '/' + b
UnicodeDecodeError
'ascii' codec can't decode byte 0xc3 in position 15: ordinal
not in range(128)
Changing the grass data directory path to only contain ascii characters
(e.g.
'/home/user/GRASSDATA') makes the Georectify tool usable. This seems to an
issue with how the python code handles path names and unicode characters.
Cheers,
Torsti
-- System Information:
Debian Release: wheezy/sid
APT prefers testing
APT policy: (700, 'testing')
Architecture: amd64 (x86_64)
Kernel: Linux 3.2.0-2-amd64 (SMP w/4 CPU cores)
Locale: LANG=fi_FI.utf8, LC_CTYPE=fi_FI.utf8 (charmap=UTF-8)
Shell: /bin/sh linked to /bin/dash
Versions of packages grass-gui depends on:
ii gnome-terminal [x-terminal-emulator] 3.4.1.1-1
ii grass-core 6.4.2-1
ii lesstif2 1:0.95.2-1
ii libc6 2.13-33
ii libfreetype6 2.4.9-1
ii libgdal1 1.9.0-2
ii libgl1-mesa-glx [libgl1] 8.0.2-2
ii libglu1-mesa [libglu1] 8.0.2-2
ii libice6 2:1.0.8-2
ii libpng12-0 1.2.49-1
ii libsm6 2:1.2.1-2
ii libtiff5 4.0.1-7
ii libx11-6 2:1.4.99.901-2
ii libxext6 2:1.3.1-2
ii libxmu6 2:1.1.1-1
ii libxt6 1:1.1.3-1
ii python 2.7.2-10
ii python-opengl 3.0.1-1
ii python-wxgtk2.8 2.8.12.1-11
ii tcl8.5 8.5.11-2
ii tk8.5 8.5.11-2
ii xterm [x-terminal-emulator] 278-1
ii zlib1g 1:1.2.7.dfsg-11
Versions of packages grass-gui recommends:
ii ghostscript 9.05~dfsg-6
ii python-imaging 1.1.7-4
grass-gui suggests no packages.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1672>
