[GRASS-dev] Problems with v.net.distance
Roberto Marzocchi
roberto.marzocchi at gmail.com
Fri Jun 15 09:12:45 PDT 2012
Dear all,
I'm trying to use v.net.distance in grass7, which option seem be corrected
respect of teh version of grass65 (alayer, nlayer and consequently costs).
First of all, I noted that the option output is reported two time, but this
can be simply corrected removing line 134 of main.c command. If needed I
can add in the svn.
Secondarly the program stop itself because if I correctly uderstand, the
number of lines not corresponding with the number of nodes.
ERROR: Nodes not available for line 8819
Unfortunately I'm not expert with vector grass libraries so I didn't
understand the problem..
I'm using as a test the north carolina dataset and in particular I do the
step of the tutorial of Trento university (
http://www.ing.unitn.it/~grass/docs/tutorial_64_en/htdocs/esercitazione/network_analysis/index.html)
adding
also a 4th layer with the nodes. Attached a script to create the dataset
(grass70)
Cheers,
Roberto
Un allegato HTML ? stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120615/57898cd8/attachment.html>
Un allegato non testuale ? stato rimosso....
Nome: network_script.sh
Tipo: application/x-sh
Dimensione: 5412 bytes
Descrizione: non disponibile
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120615/57898cd8/attachment.sh>
