[GRASS-dev] still problems with overwrite in scripts
Glynn Clements
glynn at gclements.plus.com
Wed Jun 27 16:06:50 PDT 2012
Michael Barton wrote:
> I thought from reading past mail posts that -o and --o and --overwrite
> all set the overwrite flag.
The last two do; the first one is just a normal flag.
Historically, modules used -o for overwrite, but that is deprecated in
favour of the --o/--overwrite option which is built into G_parser().
> I test for overwrite with grass.overwrite()
> But how do I include a check box for the overwrite flag in the GUI specs
> (for g.parser)?
If any of the options have a gisprompt setting which starts with
"new", the --help output will display the --o flag and the GUI will
have a checkbox to enable overwrite.
In 7.0, you can force the existence of the overwrite flag by adding
"#% overwrite: yes" to the module options, but this doesn't work in
6.x, partly because it isn't implemented in g.parser and partly
because the underlying logic in G_parser() is broken; see:
https://trac.osgeo.org/grass/ticket/1658#comment:1
