[GRASS-dev] [GRASS GIS] #1600: band skip or specify multiple bands
in r.in.gdal
trac at osgeo.org
Tue Mar 6 18:56:53 EST 2012
#1600: band skip or specify multiple bands in r.in.gdal
Reporter: cmbarton | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
In working with NetCDF files, I realize that it is important to be able to
skip bands in order to import a coherent data set (e.g., import bands
1,5,9,13.17...). This is especially important when importing times series
for the new temporal GIS format in GRASS 7.
There are a couple ways to do this. Assuming that there is a constant band
interval (e.g., every 12 bands to import climate data for July for 100
years) a skip argument could be implemented (skip=12 to import every 12th
band).
For more control but more work, extending the band= argument to accept a
comma separate list could achieve the same result albeit with more typing
or cut and past (e.g., bands=1,13,25,37,49,...).
Both methods could be implemented, but the bands= list should probably
override the skip= argument in that case.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1600>
