[GRASS-dev] [GRASS GIS] #1620: cartographic composer doesn't work properly with vector data
GRASS GIS trac at osgeo.org
Fri Mar 16 04:18:31 EDT 2012
 Reporter:  madi                           |       Owner:  grass-dev@…
     Type:  defect                         |      Status:  new
 Priority:  normal                         |   Milestone:  7.0.0
Component:  Ps.map                         |     Version:  svn-trunk
 Keywords:  cartographic composer, ps.map  |    Platform:  Linux
      Cpu:  x86-64                         |
 I get a strange behavior from the cartographic composer when I try to
 print in the same canvas both rasters and vectors, in the ps file most of
 the output is black, see attached image. No problem if I use only raster
 maps.
 Thanks,
 madi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1620>
