[GRASS-dev] Re: [GRASS GIS] #1620: cartographic composer doesn't
work properly with vector data
trac at osgeo.org
Fri Mar 16 08:10:23 EDT 2012
#1620: cartographic composer doesn't work properly with vector data
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Ps.map | Version: svn-trunk
Keywords: cartographic composer, ps.map | Platform: Linux
Cpu: x86-64 |
Comment(by annakrat):
There's not enough information. Could you export the script for ps.map
module from the composer and run it with ps.map if the result is the same?
Also it could help to attach this script.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1620#comment:1>
