[GRASS-dev] GRASS7: libgrass_vector.so has odd libraster dependency: libgrass_raster.7.0.svn.so not found
Markus Neteler neteler at osgeo.org
Fri Mar 16 12:47:59 EDT 2012
On Thu, Mar 15, 2012 at 4:16 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> on a system-wide installation (make install done) we get this bug:
>> # user not being me:
>> v.in.ascii: error while loading shared libraries:
>> /home/neteler/software/grass70/dist.x86_64-unknown-linux-gnu/lib/libgrass_raster.7.0.svn.so:
>> cannot open shared object file: Permission denied
>> I don't like this dependency too much but in essence the upper
>> mentioned off library linking
>> is the real problem (which I don't know how to solve).
> This is due to r47525. It should have been $(RASTERLIB), not
> $(RASTERDEP).
Thanks for tracing this down.
> The *LIB variables contain the linker switch for that library (e.g.
> -lgrass_raster.7.0.svn). If using static libraries, it will also
> contain the linker switches for any dependencies (shared libraries
> have embedded dependency lists).
> The *DEP variables contain the full pathname of the library; they're
> intended to be used for setting DEPENDENCIES in the Makfile of a
> module which uses the library.
Hopefully fixed in r51085.
Markus
