[GRASS-dev] t*. modules
Sören Gebbert soerengebbert at googlemail.com
Thu Mar 29 14:16:19 EDT 2012
The suggested naming scheme sounds reasonable. Following this scheme,
modules should named like this?:
t.*:
t.create
t.sample
t.topology
t.rast.*:
t.rast.aggregate
t.rast.to.rast3
t.rast.mapcalc
t.rast3.*:
t.rast3.mapcalc
t.rast3.extract
t.rast3.list
t.vect.*:
t.vect.what.strds
t.vect.observe.strds
t.vect.extract
Does this sounds correct and reduces confusion?
Best regards
Soeren
Am 29.03.2012 18:36 schrieb "Markus Neteler" <neteler at osgeo.org>:
> 2012/3/29 Martin Landa <landa.martin at gmail.com>:
> > Hi,
> > 2011/10/20 Sören Gebbert <soerengebbert at googlemail.com>:
> >> with the temporal extension i introduce new datatypes to grass7:
> >> The purpose of the t.* modules is to ...
> This is the right prefix... while
> > I would like to open the discussion about this topic again, before
> > tgis extension will be announced and users will start to use it. I
> > would suggest to use only *one* prefix (`t.`) for TGIS. To extend
> > current list of prefixes (r., v., etc) with so many new prefixes which
> > are related to the one topic (in this case temporal GIS) is not good
> > idea I think. Moreover it will make user manual less readable [1] -
> > see t.*, tr.* and so on. I would propose rename eg `tr.` to `t.rast.`,
> > and so on.
> .. I agree with Martin that we currently get a confusing list of new
> prefixes which are not in line with the existing naming scheme.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20120329/8ec5f305/attachment.html
