[GRASS-dev] [GRASS GIS] #1651: Map display Query Vector tool fails
GRASS GIS trac at osgeo.org
Thu May 3 09:50:52 EDT 2012
 Reporter:  vincent      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  wxGUI        |     Version:  svn-releasebranch64
 Keywords:  queryvector  |    Platform:  Linux
      Cpu:  Unspecified  |
 When simply displaying a contour line vector, the Query Tool (this located
 in the map display toolbar) works fine, i.e. in my case one can access z
 values stored in the related attribute table. Attributes are stored in a
 postgres DB.
 Then I change the display rule for the map, e.g. only showing major
 contour lines, via this 'where' argument :
 z % 50 = 0
 Now the Query Tool fails, giving this error message :
   File "/usr/local/grass-6.4.3svn/etc/wxpython/mapdisp/mapwi
 ndow.py", line 904, in MouseActions
 self.OnLeftUp(event)
 ndow.py", line 1105, in OnLeftUp
 self.parent.QueryVector(self.mouse['begin'][0],
 self.mouse['begin'][1])
   File
 "/usr/local/grass-6.4.3svn/etc/wxpython/mapdisp/frame.py",
 line 809, in QueryVector
 qlayer = self.AddTmpVectorMapLayer(mapName, cats, useId =
 False)
   File
 line 862, in AddTmpVectorMapLayer
 parg,pval = p.split('=')
 ValueError
 too many values to unpack
 Invoking a more "sql-basical" condition (e.g. z > 1800), this error does
 not happen.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1651>
