[GRASS-dev] Re: reducing screen clutter
Rainer M Krug r.m.krug at gmail.com
Fri May 25 03:43:02 EDT 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 24/05/12 17:57, Benjamin Ducke wrote:
> This sounds like a familiar problem. Most file/web browsers let the choose whether to stay in
> the same window or open a new one when browsing to a new location.
> So perhaps there should be an option in the GUI to "allow multiple windows per module" which
> could be set to "false" by default?
This would be a good (and intuitive) suggestion.
Cheers,
Rainer
> Ben
> On 05/24/2012 05:34 PM, Paulo van Breugel wrote:
>> True that having the same dialogue open several times can be annoying. But not always, it may
>> come in handy if you want to run the same module several times with different parameters (run
>> at the same time, or prepare one while the other is still running; btw, I actually never
>> checked how it is handled if you run the same function twice in parallel, are they run at the
>> same time on different cores?).
>> On Thu, May 24, 2012 at 4:18 PM, Michael Barton <Michael.Barton at asu.edu
>> <mailto:Michael.Barton at asu.edu>> wrote:
>> This is one way, but not exactly what I was talking about. In fact, sometimes it is very
>> useful to keep a dialog box open to rerun the same module repeatedly with different
>> parameters.
>> What I meant is that once it is open, GRASS should not open additional dialogs for the same
>> module but simply reuse the one that is open. That way you never get 5 windows for
>> v.distance, only 1--even if you leave it open.
>> Michael
>> On May 24, 2012, at 2:26 PM, Moritz Lennert wrote:
>>> On 24/05/12 12:25, Chemin, Yann (IWMI) wrote:
>>>> Maybe we can modify the GUI preferences:
>>>> Default: All dialog boxes close after a run is complete In Preferences: Tick this box if
>>>> you want the dialog boxes to be
>> closed
>>>> manually (i.e. stay after a run)
>>> The tick box already exists, so you are suggesting to make
>> closing the dialog the default ? I find it quite useful, especially for newbies, to have the
>> dialog open and be able to correct wrong input, instead of having to fill the whole dialog
>> out again... But I can confirm that it takes some teaching to make them aware of that feature
>> and avoid that they open the same command ten times. ;-)
>>> Moritz
>> _____________________ C. Michael Barton Visiting Scientist, Integrated Science Program
>> National Center for Atmospheric Research & University Consortium for Atmospheric Research
>> 303-497-2889 (voice)
>> Director, Center for Social Dynamics & Complexity Professor of Anthropology, School of Human
>> Evolution & Social Change Arizona State University www: http://www.public.asu.edu/~cmbarton
>> <http://www.public.asu.edu/%7Ecmbarton>, http://csdc.asu.edu
>> _______________________________________________ grass-dev mailing list
>> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> grass-dev at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/grass-dev
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk+/OAYACgkQoYgNqgF2egoOywCdHAl1MxCI4Fi4Ituw2IDQL5TU
0r4An3TpuTLw2450rv56I9i9U4hh9vL2
=FSsI
-----END PGP SIGNATURE-----
