[GRASS-dev] reducing screen clutter
Benjamin Ducke
benducke at fastmail.fm
Thu May 24 11:57:30 EDT 2012
This sounds like a familiar problem. Most file/web
browsers let the choose whether to stay in the same
window or open a new one when browsing to a new
location.
So perhaps there should be an option in the GUI to
"allow multiple windows per module" which could be
set to "false" by default?
Ben
On 05/24/2012 05:34 PM, Paulo van Breugel wrote:
> True that having the same dialogue open several times can be annoying.
> But not always, it may come in handy if you want to run the same module
> several times with different parameters (run at the same time, or
> prepare one while the other is still running; btw, I actually never
> checked how it is handled if you run the same function twice in
> parallel, are they run at the same time on different cores?).
> On Thu, May 24, 2012 at 4:18 PM, Michael Barton <Michael.Barton at asu.edu
> <mailto:Michael.Barton at asu.edu>> wrote:
> This is one way, but not exactly what I was talking about. In fact,
> sometimes it is very useful to keep a dialog box open to rerun the
> same module repeatedly with different parameters.
> What I meant is that once it is open, GRASS should not open
> additional dialogs for the same module but simply reuse the one that
> is open. That way you never get 5 windows for v.distance, only
> 1--even if you leave it open.
> Michael
> On May 24, 2012, at 2:26 PM, Moritz Lennert wrote:
> > On 24/05/12 12:25, Chemin, Yann (IWMI) wrote:
> >> Maybe we can modify the GUI preferences:
> >> Default: All dialog boxes close after a run is complete
> >> In Preferences: Tick this box if you want the dialog boxes to be
> closed
> >> manually (i.e. stay after a run)
> > The tick box already exists, so you are suggesting to make
> closing the dialog the default ? I find it quite useful, especially
> for newbies, to have the dialog open and be able to correct wrong
> input, instead of having to fill the whole dialog out again... But I
> can confirm that it takes some teaching to make them aware of that
> feature and avoid that they open the same command ten times. ;-)
> > Moritz
> _____________________
> C. Michael Barton
> Visiting Scientist, Integrated Science Program
> National Center for Atmospheric Research &
> University Consortium for Atmospheric Research
> 303-497-2889 (voice)
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> www: http://www.public.asu.edu/~cmbarton
> <http://www.public.asu.edu/%7Ecmbarton>, http://csdc.asu.edu
> grass-dev mailing list
> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
