[GRASS-dev] [GRASS GIS] #1663: Tabs in C source code
GRASS GIS trac at osgeo.org
Fri May 25 01:20:23 PDT 2012
 Reporter:  wenzeslaus          |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  normal              |   Milestone:
Component:  Default             |     Version:  unspecified
 Keywords:  indent tabs spaces  |    Platform:  All
      Cpu:  All                 |
 I assume that GRASS C source code should be indented with spaces, more
 precisely with spaces only. And more over, mixing tabs and spaces is a bad
 practice.
 But C source files contains both spaces and tabs.
 For example changeset r47676 "code layout fixes with indent" only adds
 another tabs which are mixed with spaces. Here is a part of file worker.c
 (http://trac.osgeo.org/grass/browser/grass/trunk/raster/r.li/r.li.daemon/worker.c):
 (tab)case FCELL_TYPE:{
 (tab)(tab)for (i = 0; i < ad->rl - used; i++) {
 (tab)(tab)(4spaces)fm->cache[used + i] = Rast_allocate_f_buf();
 (tab)(tab)}
 (tab)(4spaces)}
 Here is minimal working example which produces badly intended source code
 (GRASS indent script, tested on Ubuntu 10.04 with GNU indent 2.2.10).
 // file test.c
 void test()
 int a,b,i;
 a =5;
 if ( a==5 ){
 for (i = 0; i < 10; i++) { b++; }
 b= b*10;
 ./tools/grass_indent.sh test.c
 // file test.c
 void test()
 (4spaces)int a, b, i;
 (4spaces)a = 5;
 (4spaces)if (a == 5) {
 (tab)for (i = 0; i < 10; i++) {
 (tab)(4spaces)b++;
 (tab)}
 (tab)b = b * 10;
 (4spaces)}
Ticket URL: <http://trac.osgeo.org/grass/ticket/1663>
