[GRASS-dev] Re: [GRASS GIS] #1663: Tabs in C source code
GRASS GIS trac at osgeo.org
Fri May 25 08:19:50 PDT 2012
  Reporter:  wenzeslaus  |       Owner:  grass-dev@…
      Type:  defect      |      Status:  closed
  Priority:  normal      |   Milestone:
 Component:  Default     |     Version:  unspecified
Resolution:  invalid     |    Keywords:  indent tabs spaces
  Platform:  All         |         Cpu:  All
Changes (by glynn):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Replying to [ticket:1663 wenzeslaus]:
 > But C source files contains both spaces and tabs.
 This is not a problem, so long as the code is indented correctly for
 8-column tabs. Trying to enforce a spaces-only policy isn't worth the
 trouble.
 If you configure your text editor with something other than 8-column tabs,
 you're on your own (just don't commit code which relies upon something
 other than 8-column tabs).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1663#comment:1>
