[GRASS-dev] Re: [GRASS GIS] #1584: error in r.walk help page
GRASS GIS trac at osgeo.org
Fri May 25 14:44:46 PDT 2012
 Reporter:  hamish  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  major   |   Milestone:  6.4.3
Component:  Docs    |     Version:  unspecified
 Keywords:  r.walk  |    Platform:  All
      Cpu:  All     |
Comment(by dkavanagh):
 There is also a mistake in the Standard Directions figure in the Movement
 Direction section. 90 should be immediately below x and the zero should be
 removed.
 Replying to [ticket:1584 hamish]:
 > one from Agustin:
 > the documentation in r.walk is wrong. It says:
 > "The default values for a, b, c, d are those proposed by Langmuir
 > (0.72, 6.0, 1.9998, -1.9998)"
 > and it should say:
 > (0.72, 6.0, -1.9998, 1.9998)"
 > because the point is that you go faster on gentle slopes and more
 > slowly on steeper slopes and those values are in m/s
 > The worrying question is whether these values are also wrong in the
 > default values of r.walk.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1584#comment:1>
