[GRASS-dev] pyGRASS: Report #1
Pietro
peter.zamb at gmail.com
Fri May 25 07:57:12 PDT 2012
Hi all!
as reported in the new web page [0] of the pyGRASS project, at the moment you
can interact with a raster map in this way (read-only): ::
# import the raster function
>>> import obj
# instantiate a Raster
>>> dtm = obj.Raster('dtm')
# open the raster in read mode 'r'
>>> dtm.open()
# get access
>>> for row in dtm[:5]: print(row[:3])
[718.0910034179688, 717.8709716796875, 717.551025390625]
>>> dtm[5][:3]
[718.051025390625, 717.7310180664062, 717.4210205078125]
>>> dtm.close()
Any hint or suggestion are welcome! The Raster class use only the grass ctypes
library.
This report and the following ones will be available to the wiki page [1].
[0] http://code.google.com/p/pygrass/
[1]
http://grass.osgeo.org/wiki/GRASS_SoC_Ideas_2012/High_level_map_interaction#Weekly_reports
