[GRASS-dev] r.modis in GRASS 7 trunk
Yann Chemin
yann.chemin at gmail.com
Thu Nov 1 01:25:20 PDT 2012
On 1 November 2012 12:29, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Oct 31, 2012 at 10:33 PM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
> > Moritz Lennert wrote:
> >> > I suggest that modules should not simply be moved from addons to
> >> > trunk, but that a developer has a close look at a module including
> >> > testing before moving it to trunk.
> >> +1, but I see Martin's point about lack of dev power. So the trade-off
> >> has to be between quality of code and value added of having a
> >> functionality in trunk even if the code is not perfect.
> > Relegating something to add-ons is a reliable way to reduce the amount
> > of developer oversight it gets. E.g. currently you can't just "make"
> > the add-ons/grass7 directory (it lacks a Makefile),
> Now there is.
Thanks !
> > so most developers
> > won't even try to compile it. If the modules were in trunk, developers
> > may notice errors or warnings as part of the normal build process.
> Agreed.
> I also think that we need the toolbox concept rather at GUI level than
> at directory level.
+1 there was an earlier discussion about using modules keywords to make
module groups...
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Yann Chemin
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121101/61e47555/attachment.html>
