[GRASS-dev] [GRASS GIS] #1778: Typing in g.region without parameters does not open a g.region window
trac at osgeo.org
Thu Nov 1 04:50:24 PDT 2012
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
Normally when you type a command, e.g., g.region, without parameters, a
new window for that command opens.
This does not seem to work for a few commands at the moment. Three ones
that seem to be affected are g.region, g.rename and g.copy.
Typing in these commands in the command console of the GRASS GIS layer
manager do open the windows
My system info:
GRASS version: 7.0.svn
GRASS SVN Revision: 53621
GIS Library Revision: 52468 (2012-07-27)
GDAL/OGR: 1.9.2
PROJ4: Rel. 4.7.1, 23 September 2009
Python: 2.7.3
wxPython: 2.8.12.1
Platform: Linux-3.5.0-17-generic-x86_64-with-Ubuntu-12.10-quantal
Ticket URL: <http://trac.osgeo.org/grass/ticket/1778>
