[GRASS-dev] making GEOS as manatory dependency for grass7 ?
Benjamin Ducke
benducke at fastmail.fm
Mon Nov 5 00:58:43 PST 2012
{snip}
>> Why should using the C standard lib's free() a bug?
> Because just using free() on something that should be released with some
> specific function assumes that that function is just a wrapper around free().
> That might not be the case or might change over time. It also ignores the fact
> that there can be multiple heap managements like on windows, when multiple
> compiler versions (and therefore their RTL) are used.
Right, I get that. I was unaware of the issue
with different heap managements. Thanks for
pointing that one out.
Cheers,
Ben
> Jürgen
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
