[GRASS-dev] making GEOS as manatory dependency for grass7 ?
Jürgen E. Fischer
jef at norbit.de
Mon Nov 5 00:41:34 PST 2012
Hi Benjamin,
On Mon, 05. Nov 2012 at 08:36:18 +0100, Benjamin Ducke wrote:
> The problems are mostly with linking compiled C++
> code. Due to the different name mangling schemes,
> a DLL produced by VC might not be usable by
> an EXE produced with MinGW and vice versa.
Right, C++ is a different beast. I was assuming we were talking about C.
> Why should using the C standard lib's free() a bug?
Because just using free() on something that should be released with some
specific function assumes that that function is just a wrapper around free().
That might not be the case or might change over time. It also ignores the fact
that there can be multiple heap managements like on windows, when multiple
compiler versions (and therefore their RTL) are used.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
committ(ed|ing) to Quantum GIS IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
