[GRASS-dev] GRASS scripting Python API error/fatal handling
Sören Gebbert
soerengebbert at googlemail.com
Mon Nov 5 16:31:58 PST 2012
sorry fir the late response.
2012/10/1 Glynn Clements <glynn at gclements.plus.com>
> Sören Gebbert wrote:
> > > For simple clean-up operations, atexit.register() is sufficient.
> > While implementing this, can we use the "raise_on_error" flag to
> > enable the raise of a ScriptError exception in fatal()?
> > It would be only a simple modification of the current code i guess.
> Yes. The only thing which needs to be done is to move the conditional
> from error() to fatal(), and check any code which might be using
> set_raise_on_error() in case it relies upon the existing behaviour.
Done in r53396.
Best regards
Soeren
Most scripts should continue to use atexit.register() for clean-up and
> not bother with exception handling.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121106/609f3064/attachment.html>
