[GRASS-dev] wxGUI lock import problem
Glynn Clements
glynn at gclements.plus.com
Tue Nov 6 16:06:37 PST 2012
Martin Landa wrote:
> > I am not sure what could be the reason. Very wild guess, couldn't be
> > related to r53674.
> quick test: after reverting this commit, the problem will not occur.
Oops. There's an infinite recursion bug in that version:
start_command
debug_level
gisenv
read_command
pipe_command
start_command
Try r53716. Although I don't know if this is actually related to the
"import lock" issue.
