[GRASS-dev] wxGUI lock import problem
Martin Landa
landa.martin at gmail.com
Wed Nov 7 00:44:20 PST 2012
2012/11/7 Glynn Clements <glynn at gclements.plus.com>:
> Oops. There's an infinite recursion bug in that version:
> start_command
> debug_level
> gisenv
> read_command
> pipe_command
> start_command
> Try r53716. Although I don't know if this is actually related to the
> "import lock" issue.
seems to be fixed. Thanks, Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
