[GRASS-dev] [GRASS GIS] #1683: error message v.db.addcol
GRASS GIS trac at osgeo.org
Wed Nov 7 04:57:59 PST 2012
 Reporter:  jradinger      |       Owner:  hamish
     Type:  defect         |      Status:  assigned
 Priority:  major          |   Milestone:  6.4.3
Component:  Shell Scripts  |     Version:  svn-develbranch6
 Keywords:  v.db.addcol    |    Platform:  All
      Cpu:  Unspecified    |
Comment(by jradinger):
 sorry for responding so late.
 today I tried example again and found out that the error messages are
 related
 a messy gisenv. Here first the errors from v.db.addcol
 v.db.addcol map="test at FIDIMO_Cele" columns="testcol DOUBLE"
 /usr/local/grass-6.5.svn/scripts/v.db.addcol: 1: eval:
 adinger/U_Radinger/05_GRASS/GR=/home/radinger/U_Radinger/05_GRASS/GRASS_Scripts:
 not found
 adinger/05_GRASS/GRASS_Scripts=/home/radinger/U_Radinger/05_GRASS/FIDIMO/FIDIMO_Script/fidimo
 for grass 6.x/r.fidimo: not found
 /r.rdfilter=/home/radinger/U_Radinger/05_GRASS/FIDIMO/FIDIMO_Script/fidimo
 GRASS 6.5.svn (Cele_location):~ >
 So I also checked the output of g.gisenv from the command line which seems
 somehow
 wrong. I looks like the output for GRASS_SCRIPTS is "chopped up" and
 messy, and I don't know how this could happen.
 GRASS 6.5.svn (Cele_location):~ > g.gisenv
 GISDBASE=/home/radinger/Documents/GRASS_locations
 LOCATION_NAME=Cele_location
 MAPSET=FIDIMO_Cele
 ADDON_PATH=/home/radinger/.grass6/addons:/home/radinger/.grass6/addons:/home/radinger/.grass6/addons:/home/radinger/.grass6/addons:/home/radinger/.grass6/addons:/home/radinger/.grass6/addons:/home/r
 ASS_Scripts=/home/radinger/U_R:/home/radinger/U_Radinger/05_GRASS/GRASS_Scripts/FIDIMO_testbed
 GRASS_GUI=wxpython
 How can I clean up my gisenv as I think that might solve the problem?
 Whats the best way? My ADDON_PATH is extremely long and repeatedly the
 same. Furthermore it seems there is a line break in gisenv dividing "r"
 and "adinger...", which is causing the problem above.
 I still don't know how this could happen as I never touched the
 gisenv deliberately.
 /j
Ticket URL: <http://trac.osgeo.org/grass/ticket/1683#comment:12>
