[GRASS-dev] [GRASS GIS] #372: v.net.iso, v.net.path: error when using it with cost point (ncolumn)
GRASS GIS trac at osgeo.org
Wed Nov 7 07:57:46 PST 2012
 Reporter:  paoloC                |       Owner:  grass-dev@…
     Type:  defect                |      Status:  new
 Priority:  major                 |   Milestone:  6.4.3
Component:  Default               |     Version:  svn-develbranch6
 Keywords:  v.net.iso nodes cost  |    Platform:  Linux
      Cpu:  Unspecified           |
Changes (by mlennert):
  * keywords:  => v.net.iso nodes cost
Comment:
 The bug is still in issue in all versions. See [1] for the original
 postings on the mailing list (the nabble link provided by the OP is dead).
 Here's how to reproduce in trunk with the NC data:
 v.net roadsmajor poi=schools_wake thresh=500 op=connect out=network
 v.db.addtable network layer=2 col="cat integer, cost integer"
 echo "update network_2 set cost=1" | db.execute in=-
 v.net.iso in=network out=isocost alayer=1 nlayer=2 ncolumn=cost ccats=1-10
 cost=5000,10000,20000
 The error is
 Setting node costs...
 ERREUR :Requested feature id 0 is not reasonable(max features in vector
 map
         <network at user1>: 457)
 The error does not appear when v.net.iso is run without the ncolumn
 option.
 The issue is in lib/vector/Vlib/net.c the for-loop starting line 377,
 based on the number of nodes (nnodes) retrieved from the map in line 133
 with Vect_get_num_nodes(Map). This gives a number of nodes which at one
 point leads to the error. Using DEBUG=2, I can see that the problem arises
 with node 265. Replacing the nnodes variable in the loop definition with
 264, the module runs.
 I still have to figure out what exactly this number of nodes represents
 (well, I know it is the number of nodes you also get as output of v.build
 network) and what it is used for here, but it certainly is not related to
 the nodes (i.e. the schools) I added with the v.net command.
 MarkusN, do you have a quick idea on this ? Otherwise, I'll continue
 looking.
 Moritz
 [1] http://lists.osgeo.org/pipermail/grass-user/2008-November/047624.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/372#comment:3>
