[GRASS-dev] wxgui encoding issues
Moritz Lennert mlennert at club.worldonline.be
Thu Nov 8 04:42:26 PST 2012
Hi all,
I'm sending this to the mailing list as I'm not sure where we're at in
terms of the discussions concerning encoding issues in the wxgui (I know
Maris has been active on the windows front). If my problems are real
bugs, then I'll post relevant tickets.
Using any version, I have the following encoding issues in the GUI
(knowing that my machine is configured with locale fr_BE.UTF-8) :
- r.reclass interactive input with accents gives me
"Traceback (most recent call last):
   File
"/home/mlennert/SRC/GRASS/grass_trunk/dist.i686-pc-linux-gnu/etc/gui/wxpython/gui_core/forms.py",
line 1738, in OnFileText
     f.write(text)
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
position 7: ordinal not in range(128)"
The same data in a file works without issues.
Here are example reclass rules for the NC landclass96 raster to reproduce:
1 = 1 développé
2 = 2 agricole
3 = 3 herbacé
4 = 4 broussaille
5 = 5 forêt
6 = 6 eau
7 = 7 sédiment
- Trying to save any model from the graphical modeller, even a
completely empty one gives me:
   File
"/home/mlennert/SRC/GRASS/grass_trunk/dist.i686-pc-linux-gnu/etc/gui/wxpython/gmodeler/frame.py",
line 868, in WriteModelFile
     WriteModelFile(fd = tmpfile, model = self.model)
   File
"/home/mlennert/SRC/GRASS/grass_trunk/dist.i686-pc-linux-gnu/etc/gui/wxpython/gmodeler/model.py",
line 1758, in __init__
     self._properties()
   File
line 1807, in _properties
     self.fd.write('%s<name>%s</name>\n' % (' ' * self.indent,
self.properties['name']))
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe8' in
position 17: ordinal not in range(128)
This second issue seems to come from line 58 in
gui/wxpython/gmodele/model.py :
self.properties = { 'name'        : _("model"),
Does this property really have to be translatable ? If I change line
1807 mentioned in the traceback to
self.properties['name'].encode('UTF-8')))
it works. What I don't understand is that I don't have to do this for
the description in the next line which also contains an accent in French.
- In all versions but 6.4.2 trying to import a file which resides in a
directory with accent in the name ("données"), I see this in the file
text field of the import wizard after browing to the file
/home/mlennert/Desktop/données/boundary_county.shp
Exploring this a bit further, I see the following behaviour:
- My own locale is defined as follows
LANG=fr_BE.UTF-8
LANGUAGE=
LC_CTYPE="fr_BE.UTF-8"
LC_NUMERIC="fr_BE.UTF-8"
LC_TIME="fr_BE.UTF-8"
LC_COLLATE="fr_BE.UTF-8"
LC_MONETARY="fr_BE.UTF-8"
LC_MESSAGES="fr_BE.UTF-8"
LC_PAPER="fr_BE.UTF-8"
LC_NAME="fr_BE.UTF-8"
LC_ADDRESS="fr_BE.UTF-8"
LC_TELEPHONE="fr_BE.UTF-8"
LC_MEASUREMENT="fr_BE.UTF-8"
LC_IDENTIFICATION="fr_BE.UTF-8"
LC_ALL=
- When I start 6.4.2 and then type 'locale' at the command prompt I get
exactly the same.
- But when I start 6.4.3RC1 I see
LANG=
LANGUAGE=
LC_CTYPE="POSIX"
LC_NUMERIC="POSIX"
LC_TIME="POSIX"
LC_COLLATE="POSIX"
LC_MONETARY="POSIX"
LC_MESSAGES="POSIX"
LC_PAPER="POSIX"
LC_NAME="POSIX"
LC_ADDRESS="POSIX"
LC_TELEPHONE="POSIX"
LC_MEASUREMENT="POSIX"
LC_IDENTIFICATION="POSIX"
LC_ALL=
and the gui starts in English.
When I set LC_ALL=fr_BE.UTF-8 before starting grass6.4.3 RC1, and the
type 'locale' at the command prompt, I get
LANG=
LANGUAGE=
LC_ALL=fr_BE.UTF-8
and the gui in French. I can then import the file from the directory
with accents, but the problems with saving the model and with using
reclass rules with accents interactively remain.
I see some differences in the way LANG and LANGUAGE are handled in
Init.sh, but I don't really understand where that comes to play for the GUI.
In any case, these encoding errors are quite an issue for my students...
So, if anyone can point me to existing discussions or bug tickets that I
have failed to find, I'm more than happy to document these issues there.
Or I can file a new ticket. Unless I'm just doing something wrong here...
Moritz
