[GRASS-dev] Area weighted rasterization with v.to.rast?
Newcomb, Doug
doug_newcomb at fws.gov
Thu Nov 8 04:57:50 PST 2012
>r.mapcalculator to divide the value of each raster by the area of a raster
cell.
This should be divide the area of a cell by the value of the raster ( from
the polygon). Sorry, no caffeine yet this morning.
Doug
On Thu, Nov 8, 2012 at 7:53 AM, Newcomb, Doug <doug_newcomb at fws.gov> wrote:
> Markus,
> The first thing that occurs to me is to make the value of the first raster
> from the polygon layer the area of the polygon. r.mapcalculator to divide
> the value of each raster by the area of a raster cell. This should give
> you a raster with the value of the proportion of area of the polygon in
> each cell.
> Now rasterize the polygon layer with the original attribute you wanted to
> affect. Multiply this raster by the proportional raster above.
> A bit brute force, but it should give you what you want.
> Doug
> On Thu, Nov 8, 2012 at 5:29 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> Hi all,
>> for a project I would be in need to rasterize vector polygons with
>> attribute value to the raster model where the resulting raster cells
>> carry the weighted portion of the original attribute according to
>> the area covered.
>> Example:
>> A square vector polygon with value 10.000 falls onto four raster
>> cells. The resulting cells should each carry the value 2.500.
>> I wonder if the mechanism used in r.resamp.stats for -w:
>> Weight according to area
>> could be implemented in v.to.rast to achieve this goal.
>> thanks
>> Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121108/1b30a360/attachment-0001.html>
