[GRASS-dev] [GRASS GIS] #1799: Selecting multiple columns in v.db.select window does not work
GRASS GIS trac at osgeo.org
Fri Nov 16 07:30:27 PST 2012
 Reporter:  pvanbosgeo  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  7.0.0
Component:  Default     |     Version:  svn-trunk
 Keywords:              |    Platform:  Unspecified
      Cpu:  x86-64      |
 Running v.db.select using the GUI: it is not possible to select more then
 one column in the dropdown menu
 GRASS version: 7.0.svn
 GRASS SVN Revision: 53783
 GIS Library Revision: 52468 (2012-07-27)
 GDAL/OGR: 1.9.2
 PROJ.4: 4.7.0
 GEOS: 3.3.3
 Python: 2.7.3
 wxPython: 2.8.12.1
 Platform: Linux-3.5.0-18-generic-x86_64-with-Ubuntu-12.10-quantal
Ticket URL: <http://trac.osgeo.org/grass/ticket/1799>
