[GRASS-dev] [GRASS GIS] #1800: v.kernel crashes after long execution
trac at osgeo.org
Fri Nov 16 12:32:37 PST 2012
Reporter: arencambre | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: | Platform: MSWindows 7
Cpu: x86-64 |
A v.kernel run on a dataset with over 700,000 points abruptly crashes
after several hours of processing:
'''v.kernel input=geocoding_after_highway_name_fix at PERMANENT
output=mockingbird_and_central_high_resolution stddeviation=100
STDDEV: 100.000000
RES: 11.176766 ROWS: 4710 COLS: 4495
Writing output raster map using smooth parameter=100.000000.
Normalising factor=64826.350188.
closecell: can't move C:\temp/dallascounty/PERMANENT/.tmp/7128.0
to cell file
C:\temp/dallascounty/PERMANENT/fcell/mockingbird_and_central_high_resolution
Maximum value in output: 2.703527e-002.
(Fri Nov 16 14:26:46 2012) Command finished (59981 sec)'''
Ticket URL: <http://trac.osgeo.org/grass/ticket/1800>
