[GRASS-dev] [GRASS GIS] #1800: v.kernel crashes after long execution
GRASS GIS trac at osgeo.org
Fri Nov 16 12:34:40 PST 2012
 Reporter:  arencambre  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.3
Component:  Vector      |     Version:  6.4.2
 Keywords:              |    Platform:  MSWindows 7
      Cpu:  x86-64      |
Comment(by arencambre):
 Sorry, the formatting got messed up. Trying again:
 v.kernel input=geocoding_after_highway_name_fix at PERMANENT
 output=mockingbird_and_central_high_resolution stddeviation=100
 STDDEV: 100.000000
 RES: 11.176766  ROWS: 4710      COLS: 4495
 Writing output raster map using smooth parameter=100.000000.
 Normalising factor=64826.350188.
 closecell: can't move C:\temp/dallascounty/PERMANENT/.tmp/7128.0
 to cell file
 C:\temp/dallascounty/PERMANENT/fcell/mockingbird_and_central_high_resolution
 Maximum value in output: 2.703527e-002.
 (Fri Nov 16 14:26:46 2012) Command finished (59981 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1800#comment:1>
