[GRASS-dev] [GRASS GIS] #1800: v.kernel crashes after long execution
GRASS GIS trac at osgeo.org
Sun Nov 18 08:16:18 PST 2012
 Reporter:  arencambre  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.3
Component:  Vector      |     Version:  6.4.2
 Keywords:              |    Platform:  MSWindows 7
      Cpu:  x86-64      |
Comment(by mmetz):
 Replying to [comment:1 arencambre]:
 v.kernel input=geocoding_after_highway_name_fix at PERMANENT
 output=mockingbird_and_central_high_resolution stddeviation=100
 STDDEV: 100.000000
 RES: 11.176766  ROWS: 4710      COLS: 4495
 Writing output raster map using smooth parameter=100.000000.
 Normalising factor=64826.350188.
 closecell: can't move C:\temp/dallascounty/PERMANENT/.tmp/7128.0
 to cell file
 C:\temp/dallascounty/PERMANENT/fcell/mockingbird_and_central_high_resolution
 Maximum value in output: 2.703527e-002.
 (Fri Nov 16 14:26:46 2012) Command finished (59981 sec)
 Is there enough free disk space? You could test with creating a dummy
 raster with the same region settings using e.g
 r.mapcalc "mockingbird_and_central_high_resolution = rand(0.0, 1.0)"
 This should tell you if the problem is specific to v.kernel or more
 general.
 BTW, v.kernel is about twice as fast in trunk r53896.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1800#comment:2>
