[GRASS-dev] [GRASS GIS] #1801: r3.in.ascii fails in GRASS6.4.3
GRASS GIS trac at osgeo.org
Sun Nov 18 21:06:00 PST 2012
 Reporter:  helena           |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  critical         |   Milestone:  6.4.3
Component:  Raster3D         |     Version:  svn-releasebranch64
 Keywords:  raster3d import  |    Platform:  MacOSX
      Cpu:  OSX/Intel        |
 r3.in.ascii produces the following error in GRASS6.4.3svn compiled today
 GRASS 6.4.3svn (nc_spm_05):~ > r3.in.ascii JR_7408MR_2m3dtest.asci
 out=testr3inasci
 Loading data ... (570x594x8)
 ERROR: asciiToG3d: read failed
 running r3.info on the created (but broken) 3d raster shows that following
 command was used:
 r3.in.ascii input="JR_7408MR_2m3dtest.asci" output="testin3d" nv="no\   |
  |    ne" type="default" precision="default" compression="default"
 tiledim\   |
  |    ension="default"
 and running r3.in.ascii --help also shows that default value is the string
 default
 rather than a valid number. I tried to run it with some reasonable numbers
 but I got
 ERROR: Error getting standard parameters
Ticket URL: <http://trac.osgeo.org/grass/ticket/1801>
