#1775: v.surf.rst does not respect mask
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.surf.rst | Platform: Unspecified
Cpu: Unspecified |
Comment(by helena):
I can confirm this ERROR when mask parameter is given in GRASS7.
Also, the output of rescaled tension fi which used to be written out with
-t flag has disappeared.
I just checked in GRASS6.4.3 and mask there works as intended - user can
define it as parameter mask=
or by setting MASK for the current mapset.
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:1>
