[GRASS-dev] graph function in r.mapcalc
Paulo van Breugel p.vanbreugel at gmail.com
Mon Nov 19 14:06:45 PST 2012
On Mon, Nov 19, 2012 at 7:07 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Paulo van Breugel wrote:
> > It works perfectly in my (limited) testing, great! I am impressed.
> > I am not sure what you mean by "re-factor the common code", but I hope it
> > will be possible to include this graph2() function as a standard as it
> > makes, i.m.h.o. the function more user-friendly.
> Can you add a "wish" to the bug tracker?
Done
> > p.s. I applied the patch to my GRASS7, can I also apply the patch to
> > GRASS64?
> I'm not sure that the patch will apply to 6.4, but there's no
> fundamental reason the same change cannot be made.
OK, thanks, I will try out
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121119/c6841d2d/attachment.html>
