[GRASS-dev] [GRASS GIS] #1775: v.surf.rst does not respect mask
GRASS GIS trac at osgeo.org
Mon Nov 19 10:09:51 PST 2012
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-trunk
 Keywords:  v.surf.rst   |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by helena):
 Glynn, thanks for the explanation - there is no reason for v.surf.rst to
 read/write multiple maps at different resolutions, I am guessing that it
 tries to read the mask at its original resolution, but it should read it
 at the same resolution as is set by g.region for output. I can try to look
 at the code when time allows,
 Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/1775#comment:4>
