[GRASS-dev] [GRASS GIS] #1802: Change in input for graph function in r.mapcalc
trac at osgeo.org
Mon Nov 19 10:29:28 PST 2012
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
The input for the graph function in r.mapcalc is a string with XY values,
like:
"newmap = graph(map, x1,y1, x2,y2,... xi,yi)"
Often, X and Y values are available as separate columns or vectors. In
such cases, it would be much easier if X and Y values can be given as
separate vectors, e.g., something like:
"newmap = graph(map, x1,x2,x3,x4,...xi, y1,y2,y3,y4,...,yi)"
Glynn Clements has already created a patch to implement this, see
http://lists.osgeo.org/pipermail/grass-dev/2012-November/060851.html. I
would like to suggest to implement this patch which will add a graph2()
function with the above syntax
Ticket URL: <http://trac.osgeo.org/grass/ticket/1802>
