[GRASS-dev] graph function input limitations
Wed Nov 21 06:39:44 PST 2012
Paulo van Breugel wrote:
> I am working with the r.mapcalc graph function. When the input (number
> of xy pairs) is very high, I am getting an error message:
> "memory exhausted
> Parse error
> ERROR: parse error"
> The largest possible number of xy pairs seems to be somewhere between
> 2400 and 2500. It runs with 2400 xy pairs, and pretty fast for that
> matter. Memory usage doesn't go beyond 1.5GB with 2400 xy pairs, while I
> have 12GB RAM (on 64bit Linux computer), so I guess RAM isn't the
> limitation here.
Each "term" in an r.mapcalc expression requires a row buffer, i.e. one
int/float/double value for each column of the map. A numeric literal
results in a row buffer filled with that value.
Depending upon what you're trying to do, it might be possible to use a
combination of r.mapcalc -> r.recode -> r.mapcalc. r.recode would use
significantly less memory than r.mapcalc's graph() function.
> In the help page of r.series, there is a mention of a soft limit of 1024
> files. Does something similar apply here (but with different numbers)?
> I can actually work around it, using a approximation of the graph
> function, but would like to know at what number of xy pairs I should
> apply the workaround. Particularly important, is the limit the same for
> all users, or if not, what would be a safe limit? Or is there a way to
> set this limit from within a script?
The limit would depend upon the number of columns in the current
region and the amount of memory available.
