[GRASS-dev] [GRASS GIS] #1803: GRASS 6.4.3RC1 on Win 7: grass64.bat fails due to UNIX line endings in Init.bat
trac at osgeo.org
Wed Nov 21 07:37:51 PST 2012
Init.bat
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Startup | Version: 6.4.3 RCs
Keywords: Init.bat, CRLF | Platform: MSWindows 7
Cpu: x86-64 |
There's a following error at GRASS 6.4.3RC1 startup in text mode on Win 7
64bit:
C:\>"C:\Program Files (x86)\GRASS GIS 6.4.3RC1\grass64.bat" -text
The system cannot find the batch label specified - aftertextcheck
The problem is in the etc\Init.bat where the "aftertextcheck" label is
used - looks like Windows expects "\r\n" at the end of the label name
rather than "\n".
Are the Windows builds done on Linux? If so, I guess the root cause is
eol-style=native on lib/init/init.bat in the GRASS repo. The solution
would be to set eol-style=CRLF, or maybe to tweak the makefile to run
tr/unix2dos/... on etc/Init.bat.
Opinions?
There are plenty of *.bat with LF instead of CRLF in the GRASS
installation dir. Shouldn't they all have CRLF line endings?:
$ cd '/c/Program Files (x86)/GRASS GIS 6.4.3RC1'
$ find . -type f -iname '*.bat' -print0 | xargs -0 grep -Ulv $'\r' | wc -l
112
Ticket URL: <http://trac.osgeo.org/grass/ticket/1803>
