[GRASS-dev] [GRASS GIS] #1803: GRASS 6.4.3RC1 on Win 7: grass64.bat fails due to UNIX line endings in Init.bat
GRASS GIS trac at osgeo.org
Wed Nov 21 09:51:49 PST 2012
Init.bat
 Reporter:  msieczka        |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  critical        |   Milestone:  6.4.3
Component:  Startup         |     Version:  6.4.3 RCs
 Keywords:  Init.bat, CRLF  |    Platform:  MSWindows 7
      Cpu:  x86-64          |
Description changed by martinl:
Old description:
> There's a following error at GRASS 6.4.3RC1 startup in text mode on Win 7
> 64bit:
> C:\>"C:\Program Files (x86)\GRASS GIS 6.4.3RC1\grass64.bat" -text
> The system cannot find the batch label specified - aftertextcheck
> The problem is in the etc\Init.bat where the "aftertextcheck" label is
> used - looks like Windows expects "\r\n" at the end of the label name
> rather than "\n".
> Are the Windows builds done on Linux? If so, I guess the root cause is
> eol-style=native on lib/init/init.bat in the GRASS repo. The solution
> would be to set eol-style=CRLF, or maybe to tweak the makefile to run
> tr/unix2dos/... on etc/Init.bat.
> Opinions?
> There are plenty of *.bat with LF instead of CRLF in the GRASS
> installation dir. Shouldn't they all have CRLF line endings?:
> $ cd '/c/Program Files (x86)/GRASS GIS 6.4.3RC1'
> $ find . -type f -iname '*.bat' -print0 | xargs -0 grep -Ulv $'\r' | wc
> -l
> 112
New description:
 winGRASS are built on Windows, of course - in MinGW/MSys environment.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1803#comment:1>
