[GRASS-dev] error in g.extension and help file not installed
Paulo van Breugel p.vanbreugel at gmail.com
Thu Nov 22 02:51:17 PST 2012
In addition: I noticed that after opening the module the help file shows
(the 'manual' tab in the modules window), but without the upper part
with synopsis, flags and parameter. This has perhaps to do with the
error message mentioned below:
On 11/22/2012 11:23 AM, Paulo van Breugel wrote:
> Hi,
> When trying to install an add-on with g.extension, it actually get's
> installed, but the error message tells me the install failed. The
> example below is with r.mess, but the same happens with other add-ons
> (like r.average, r..
> Fetching <r.mess> from GRASS-Addons SVN (be patient)...
> Compiling...
> /usr/local/grass6.4.current/grass-6.4.3svn/include/Make/Scri
> pt.make:47: warning: overriding commands for target
> `install'
> /usr/local/grass6.4.current/grass-6.4.3svn/include/Make/Rule
> s.make:90: warning: ignoring old commands for target
> `install'
> `install'
> `install'
> `install'
> `install'
> ERROR: G_getenv(): Variable LOCATION_NAME not set
> /bin/sh: 1: cannot create /usr/local/grass6.4.current/grass-
> 6.4.3svn/locale/scriptstrings/r.mess_to_translate.c:
> Directory nonexistent
> `install'
> `install'
> `install'
> `install'
> Installing...
> `install'
> `install'
> /usr/bin/install: cannot stat
> `/home/paulo/Data/GRASSdb/test/PERMANENT/.tmp/paulo-
> HP-Z600-Workstation/9886.0/r.mess/man/man1/r.mess.1': No
> such file or directory
> make: *** [install] Error 1
> Installation failed, sorry. Please check above error messages.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121122/ef05ce2d/attachment.html>
