[GRASS-dev] error in g.extension and help file not installed
Paulo van Breugel
p.vanbreugel at gmail.com
Thu Nov 22 02:23:13 PST 2012
When trying to install an add-on with g.extension, it actually get's
installed, but the error message tells me the install failed. The
example below is with r.mess, but the same happens with other add-ons.
Fetching <r.mess> from GRASS-Addons SVN (be patient)...
Compiling...
/usr/local/grass6.4.current/grass-6.4.3svn/include/Make/Scri
pt.make:47: warning: overriding commands for target
`install'
/usr/local/grass6.4.current/grass-6.4.3svn/include/Make/Rule
s.make:90: warning: ignoring old commands for target
`install'
`install'
`install'
`install'
`install'
ERROR: G_getenv(): Variable LOCATION_NAME not set
/bin/sh: 1: cannot create /usr/local/grass6.4.current/grass-
6.4.3svn/locale/scriptstrings/r.mess_to_translate.c:
Directory nonexistent
`install'
`install'
`install'
`install'
Installing...
`install'
`install'
/usr/bin/install: cannot stat
`/home/paulo/Data/GRASSdb/test/PERMANENT/.tmp/paulo-
HP-Z600-Workstation/9886.0/r.mess/man/man1/r.mess.1': No
such file or directory
make: *** [install] Error 1
Installation failed, sorry. Please check above error messages.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121122/c625f3e1/attachment.html>
